1 - 4 of 4 Posts
After much modifying I have installed a Front Runner rack system. It was not easy and many of the pressed-in nuts failed on removal of the factory rack. Glad I replaced it as it's crap when it comes to handling weight and really not designed for overlanding. Lots of extra waterproofing because F*#k that after all I did to get it on properly. Looks great and will handle all the items I will be mounting onto it.
I really liked the low profile and versatility of the rack system to build onto or from. The only real downside was installation, Pulling down the headliner for some spots that are not accessible unless a new hole is made or a couple B pillar supports need to be removed. I chose to upgrade the mounting bolts also and use nyloc nuts as you do not want to remove the headliner twice.
Have iPhoto issue so no pics at this time but soon I hope.
Thanks for documenting it
I’ve been toying with the idea so this is wanted and useful info!
Sent from my iPhone using Tapatalk Pro
pics?
  • Like
Reactions: Wyo Wolverine
yes Pics
1 - 4 of 4 Posts
