1 - 15 of 15 Posts
i was trying to take out one of the bolts for the xoskel front light cage and the passenger side bolt is just spinning? need advice on removing it?
Veteran - AKA Truffle's
Correct way to do it is to
1) Pull the headliner down
2) Drill out the old rivet by holding the bottom and then buy a new rivet with knurled edges.- something like this check length though
Fastenal Part No. (SKU): 0125713
-To insert the rivet look up hand made tools like this
http://www.soundsfishy.net/misc/PictureA.png
3) then put it back together.
i got the bolt out but the piece it screws into got mangled in the process what part is that and where could i possible get one?
Has anyone taken the bolts out and replaced them with a standard nut and bolt pinching the roof with something like a neoprene washer?
I tried to remove the rack the other day and was lost in spin city, was very annoyed when i dropped the headliner and saw rivets.
Be warned:
If you do that you will have to drop the headliner EVERY time you need to remove a roof rack bolt. That could be never but that 1 time you will curse yourself:banghead:
Couldn't be further from the truth.
As long as you don't torque down super tight on them when you put them back in you won't have problems. I had my custom rack up there with them barely past hand tight and it was solid as a rock. When I went to take off the rack for coating they all came right out.
Be warned:
I doubt I'll ever remove it, its been up there for 210k already. I wanted to take it off for a full paint job but after the issues. I'm set on just taping everything off really well and painting on the car.
1 - 15 of 15 Posts
