1 - 5 of 5 Posts
Am installing a new stereo and had a question on what the rear connectors are on the Rockford Fostgate unit.
I now what the lower two connectors are for but what are the upper two? I assume that the one with lots contacts is for the steering wheel but what is the one with the 3 wires for?
2006 Xterra
Mo
Center Connection
Hey All, I am new to the forum. I am in the same boat. I don't care about the XM Satellite connection. So is the one next to the top right for the steering wheel controls?
Thanks,
Sean
This is from the 2011 manual for an X with RF, Aux in, and Bluetooth
Wire Color L is Blue
M42
41 Satellite Radio Audio Input Left -
42 Satellite Radio Audio Input Left +
43 Satellite Radio Audio Input Right -
44 Satellite Radio Audio Input Right +
48 Satellite Radio Request Signal
49 Satellite Radio Communication Signal
50 Satellite Radio Communication Signal
M44
12 Amp on/off signal
13 Audio Out To Amp Left Rear -
14 Audio Out To Amp Left Rear +
15 Audio Out To Amp Right Rear -
16 Audio Out To Amp Right Rear +
M45
61 Bluetooth Sound Input –
62 Bluetooth Sound Input +
63 Bluetooth Mute Control
67 Shield ?
69 Steering Wheel Control Signal A
70 Steering Wheel Control Signal B
71 Steering Wheel Control Ground
73 Vehicle Speed Signal
74 Aux In Plug Right +
75 Aux In Plug Left +
76 Aux In Plug Ground
M46
1 Audio Out To Amp Left Front –
2 Audio Out To Amp Left Front +
3 Audio Out To Amp Right Front –
4 Audio Out To Amp Right Front +
6 Constant Power
7 Illumination Dimmer Control Input
8 Illumination On/Off
10 Ignition Switch Power
1 - 5 of 5 Posts
