1 - 3 of 3 Posts
So I'm replacing the u-joints on my X tomorrow (2wd) and I was wondering if anyone had any insights that could be useful.I've never done u-joints before but I've read around and it seems pretty straight forward. I'm planning on using the loan a tool thing at Advance to get a ball joint press so that's what I'll be using unless someone says otherwise. I was also wondering if there was someone on here that wouldn't mind giving me there number incase I run into a situation of some kind. I'm probably over thinking it but I'd rather be over prepared than under. Suggestions and words of wisdom appreciated.
Also, is there a way I can get hold of an older version of the Autoguide app? My phone runs android 2.3 and the only one on the play store is for 4.0 and above.
before removing any bolts.... make some marks on the drive shaft on both ends and the flanks... so you re-installed the same way it came from the factory
1 - 3 of 3 Posts
