1 - 4 of 4 Posts
· Registered
Hey all,
I am replacing my spark plugs soon and was wondering if I should replace anything else while I am in there? I have a 2010 Xterra 4x4 SE with 138k miles and I am not sure if the plugs were replaced. Looking for tips from anyone who has done this project before.
Thanks,
Deckard
· Registered
There really isn't anything else "while in there".
If your pulling the intake you could choose to change the valve covers - the gaskets will need that eventually anyway. However I am assuming your following the how to hear about doing plugs without taking the manifold off?
Some guys change coils. I never have - I am at 376,000 or so :ROFLMAO:
· Registered
Canadian 05 Xterra base with small upgrades.
I took my manifold off, it was much easier and I changed the manifold gaskets because of this. You can clean your throttle body while doing this as well.
Beyond that valve covers is a bigger job and I'd only do it if I found oil leaking or oil on the spark plugs you remove.
· Registered
Wow you haven't noticed any performance issues ?
1 - 4 of 4 Posts
