A month ago my check engine light came on and it coded P0345. I replaced the sensor with a Duralast from Autozone. It was ok for about a month and then it started dying out of nowhere. I got an oil change at the dealership and they told me that after market parts don't like to work on Nissans.... So I replaced the previous one with one from the dealership parts store. Well today, as my wife is sitting in the car at work, it just died on her twice. It started up fine right away. Autozone checked the alternator and battery the other day and they passed. Does the dealership normally check these things (alternator, battery) on their multi-point inspections anyways? They did tell me my battery was leaking, it is less than a year old, but I didn't see any leaking and neither did the Autozone tech. Could this still be an alternator issue? Other threads I have seen stated that all the sensors do not need to be replaced at the same time, only the one that threw the code... is this not the case after all?
Any help on this matter would be appreciated.
EDIT:
Alternator is good.... I guess now it is on to the fuel pump.... Or maybe the crankshaft sensor....
UPDATE:
So I replaced the Crankshaft Sensor as well as the Bank 1 Camshaft Sensor, so all three are brand new OEM Nissan parts. The crankshaft sensor is a pain in the ass to get to... with the correct tools, a wobbly ratchet extension, it would have been much easier to unscrew the bolt that is holding the sensor.
I have seen some things that the Bank 1 Camshaft Senor is easier to get at from this direction, under the wheel well, but unless you have super skinny arms and skinny fingers, I don't see how this can be the case.
When the dealer advised me that they usually replace all three, that they also do an idle reset... Is this something I can have them do at anytime or I need to get it done ASAP.... or is it even relevant at all?
Now let's hope this is the solution and I don't need a fuel pump after all...
Thanks for all of your help!
2012 Xterra 90k miles
EDIT:
UPDATE:
