1 - 7 of 7 Posts
So i want to change my fog lights.i believe the bulb is H11....correct me if im wrong. Im not sure if i want to go with the super bright yellow, or the white lights....i think they both look pretty cool. Should i go with amber LEDs for the yellow
You can also use the yellow version of THIS and paint your fog light lens'! Works great, and if you don't like it acetone or nail polish remover will take it right off. I used it on my PIAA's and they came out pretty sweet. Pics are in my build thread.
I have been running yellow H9 bulbs in my factory fogs for several years now and have had no problems. If you do convert to the H9, I highly recommend going with the yellow bulb. The H11 keeps the beam pattern very low, which is what you want in a fog light. The H9 is a high-beam bulb, so you light up stuff way up off the ground. Going with the yellow color will help reduce glare back in your eyes and help you keep more of the fog functionality.
That's just my $0.02.
1 - 7 of 7 Posts
