1 - 2 of 2 Posts
· Registered
‘10 Off Road, 6-speed, 2” lift.
I searched but didn’t find what I was looking for. It’s probably there somewhere.
I’m thinking of swapping the factory roof lights for a light bar. Wanting to use the factory wiring for the light bar. Where is the fuse located? What amp? Any issues I might run into? I know there is some sort of light cover switch involved in the factory lights. Any recommendations on handling that?
Thanks for any helpful info!
· Registered
If you are switching to a LED light bar then the factory power going to the stock lights should be fine. I just replaced my roof boobs not long ago but did not use LED and ran all new lines, fuses and distribution block. Here is a post I used to do some of the wiring along with my input after I did mine.
1 - 2 of 2 Posts
