1 - 7 of 7 Posts
I want to remove my running boards for a day and then put them back on when I am done wheeling. I went under and felt where the screw into the X and I could not find where the back of the bolt was, I could only find the nut. Is the boly permanantly stuck there and you just unscrew the nut and remove the boards and then leave the bolt there with nothing on it? I did a search but could not find anything to answer this question.
Yup. There are 6 studs (3 sets of 2 - one over the other) on the inside of the body lip. Take the nuts off (takes about 2 minutes with an air wratchet... 4 minutes without) and lift them off. To put them on, reverse.
1 - 7 of 7 Posts
