1 - 18 of 18 Posts
First the spare tire makes me look like an ass at work when I can't remove it from the chain. Now this.
I picked up an EC rearview mirror, but I can't get the stock one off. I picked and poked at it for 20 mins with no avail. Anyone want to share some wisdom, or maybe a voodoo doll.
Thanks
--Matt
DO NOT try to get the adhesive off. There have a been a few people report that they took a chunk out of their windshield trying to pull/pry it off. Leave the metal mount attached to the windshield and just unscrew the mirror. The new mirror should be able to use the stock mount if you bought the correct mirror.
As for the spare. Just crank the chain all the way down, reach under and turn the plate on it's side and pull through the hole. Not that hard. But I would lower and raise the tire a few times a year even if you don't need it. My brothers 99 GMC the chain rusted and we couldn't lower it. We had to cut the chain.
Straight from GW-59 of the 05 Service Manual. So you are right, there is no screw.
Removal
1. Remove inside mirror finisher (if equipped).
2. Slide the mirror upward to remove.
3. Disconnect the connector (if equipped).
Installation
Installation is in the reverse order of removal.
If you do a search I am pretty sure someone did a how-to on replacing the mirror.
Super Moderator
Step 7.2 of EC Mirror Installation Instructions
Remove OE rear view mirror from windshield:
1) Insert the flat end of 4mm flat screwdriver into the opening at the bottom of the mirror mount at the windshield.
2) Slide screwdriver into the center of the mirror mount until resistance is felt. Apply a small amount of additional upward force to lift away a locking spring in the mount.
3) While still applying upward pressure with the screwdriver, grasp the mirror bracket and lift mirror up toward the headliner and off the mirror mounting bracket.
For full set of instructions, click here.
Discussion Starter · #10 ·
I have the same instructions and that part is where I'm having the problems. No matter where or how I put the screw driver into the mirror base, there is never any resistance. What I'd know is if anyone has a trick for stubborn mirrors.
--Matt
I noticed mine was stiff as well. What I found was that you needed to push the screwdriver into the center of the housing and push on the screwdriver even more. This forces the spring catch there to move back away from the button mount and release the mirror. Almost like the action of pushing the scrwdriver all the way in caused it to release.
Interesting; after reading these posts I was expecting a fight on the mirror removal. I pressed the little 4mm flat blade in the bottom of the mirror mount hole with a moderate amount of force (basically just to feel the spring tension), it flew off and hit my right shoulder... well before I had my other hand on it. Mine definitely was not stuck as others have experienced.
Jut an FYI, auto glass repair places do not repair damage to the inside of the windshield. I had them simply reattach the mirror in lieu of a $400 replacement windshield. There is still a little of a chunk visible.
1 - 18 of 18 Posts
