1 - 2 of 2 Posts
just like the title says.
going out to pull the plastic off & see if the hatch handle got disconnected or something.
Any ideas on a quick fix
:clown: If your auto-lock sys works and you can hear the relay, at the handle, then the rod connecting it to the hatch (latch)mechanism has slipped out of its "L" slot--
--If you can't hear the auto-lock relay(at the handle) work, then the door won't un lock--
--If alll that sys works and the handle moves freely, then the cable that operates from the hatch handle, to the hatch (latch) Mech. has either broke or slipped out of the keeper, at the handle (inside)--good luck--
-- :geek: :geek: --JIMBO
1 - 2 of 2 Posts
