1 - 6 of 6 Posts
the rear hatch only locks and unlocks with the key? the keyless entry does not activate or deactivate the lock on the rear hatch??? that might just be the first design flaw that i have uncovered in my x...
well in that case my hatch is not working properly...the keyless entry device does not control my hatch at all...that sucks... looks like i have a date with nissan
On mine, you have to hit the button twice with no (or very little) delay between presses so just be sure to check that out too. When you hit the lock button while standing by the rear hatch you should hear the lock (unless of course it isn't working. But you probably already tested that too!) looks like a trip to the stealership for you!
I can hit the Door locks, ALL doors & hatch lock THunk. It unlock.. all DOORs Unlock.
OR use key in rear hatch two dble twists.. unlocks all doors. OR the driverside.
Wish inner latch on hatch to open... pain in the butt, if sleeping in back.. have to lay carpet over lock. grrrrrrrr
1 - 6 of 6 Posts
