I’ve searched for the “right” rear flood light option for a while now, and I think I finally found it.
$11 480lm LED dome light. It’s fully potted, and surprisingly high quality for the price. It’s BRIGHT. Floods a really big area around the back of the truck. I added a small toggle switch hidden in the first-aid recess.
It is tapped off of the rear 12v socket. You could also run it off the dome light, but it will “time out” with the interior lights. I wanted discrete control.
www.superbrightleds.com
LED Interior Trailer Dome Light - Surface Mount - 480 Lumens - Rectangle - 12V/24V
MR series Rectangle LED Light provides a bright task light for the interior of trailers and other low voltage applications. Polycarbonate lens and housing is impact resistant and sealed against moisture. Low profile easily surface mounts to vehicle surfaces with included pigtail wires and...
