1 - 7 of 7 Posts
Has anyone here had any problems with the rear diff leaking ? My X is still under warranty so when I first noticed the issue I brought it in and they put a new diff cover on and sealed it up. And now here it is 7 months later and it is leaking again more than before, I checked the bolts they were all tight. I brought it up to the dealer and as I type they are putting another on and resealing it? I'm just wondering if anyone has had this happen ?
2010 OR model 32,000 miles
My first X was a 2006 and I put over 100000 mi on it and it never had an issue
My rear diff was seeping oil from the cover since probably around 19k miles but it didn't seem like it was dripping oil so I held off doing anything. I took it in to the dealership at around 24k miles to look at and they said they'd pull the cover and reseal. I had intended to do the BTF cover at some point anyway so I told the dealership to just leave it. Last month at around 26k miles, I got around to getting the BTF cover with the Mag Hytec gasket and put that on. Should take care of the seeping/leaking issue.
If you don't intend to get an aftermarket diff cover, maybe trying using the Mag Hytec gasket with the stock cover. I know some say the gasket is a waste of money and RTV is the way to go but if an $18 gasket keeps the cover from leaking, I'd say it's worth it.
Thank you guys for your input!! I will explore my options and look into the gasket and other options..
1 - 7 of 7 Posts
