1 - 8 of 8 Posts
2006 Off Road 4x4
When I try to engage the e locker the light flashes and will never engage. I've tried waiting, going forward, going in reverse and leaving it in neutral. Never worked since I bought it 10k ago. Any ideas or common problems? Searched to no avail.
is it in 4low when your trying to engage, I don't have a locker but if my memory serves me right you have to be in low for it to engage. If so check the plug at the diff to make sure it's still attached, and no breaks in the wire.
Well I feel silly. Turning the wheels worked. Thank you.
No prob. If you engage it on the trail when needed, you wont need to turn, as it will engage when one wheel either slips due to low traction, or rotates freely in the air.
In stock configuration there is only one locker (rear) and yes, the light should go on and stay on when the axle is locked. If it is blinking it means you are feeding 12V to the solenoid but the locker is not actually engaged.
1 - 8 of 8 Posts
