Im planning on a little maintenance in the next week or two including engine oil & filter, both diffs and the t -case. Ill throw in a new air filter too and clean up some rust thats starting at the rear wheel well door trim area. its not very large yet but looks like its growing fast. oh yeah, need to adjust(tighten) the parking brake as well. I did the trans fluid itself like a few months ago so its good.
getting all my stuff lined up, i have all the fluids ill need. last time i was under the truck i noticed my rear diff had what looked like alittle oil seeping through the bottom of the rear diff cover, and some of the factory gasket maker material that had squished out was kind of cracked and coming apart, long story short i think its starting to leak. its not actually leaking yet if that makes sense.
anywho, i figured instead of just swapping the fluid i'd actually take of the cover and re do the seal. now, I have never done this particular job so just looking for a few questions answered and pointers.
so far my thought process is:
drain rear diff
remove rear diff cover
use plastic bag to cover the gears
scrape off the old sealant from the diff housing
scrape off the diff cover mating surface
clean both
apply oil resistant gasket maker to either the diff or the cover(which is better?)
lightly install diff cover and screws, let the gasket maker set for a few hours? not sure how long..
tighten diff cover
install drain plug with small amount of gasket maker
fill diff
install fill plug with small amount of gasket maker.
questions:
how long do i need to let it sit for before tightening and refillin?
how much gasket maker should i apply and where should i apply it?
im worried about the sealant getting into the inside of the diff when it gets squished as i tighten the cover bolts, is that an issue that i need to worry about?
there isnt an actual gasket right?
should i spray down the gears/ inside of the diff housing with anything to clean it?
any tips or suggestions?
i have 2 bottles of 75w90 lucas gear oil full syn.
drain rear diff
clean both
tighten diff cover
fill diff
questions:
