This post will seem like it belongs in the Suspension section...but maybe both there and here?
I have been having an intermittent clunk on my calmini lifted 2005 offroad. The clunk sounds like the right rear quarter area. This has been coming and going for probably a month. You can feel a bit of the clunk in the floor, or so it seems. The clunk occurs when you start from a dead stop. I think it has to be something connected to the body / Frame.
So, today I finally had some time to throw the truck on jack stands. I thought for sure I would find a loose spring mounting bolt, shock, or? Nothing I can find. I had to stop working, so didn't have time to check the torque specs.
With the truck in the air, I tried wiggling the axle back and forth to see if I could hear the clunk. What I heard is interesting. With the tire on, you can get a little clunk at the wheel. I had my son wiggle the tire and I pinched the rotor against the backing plate and could stop the movement.
Also, if you turn one tire, the other side turns. You cannot hold one tire while the other is turned...they feel locked. The truck does not act locked when driving however.
If you will recall, I took the truck into the dealership some months ago due to a leak where the locker wiring goes into the diff housing. When I got the truck back, it was stuck in the locked position. I drove home with it locked, about 30 miles on the freeway. When I got home, the truck was jolting pretty good on turns. I took it into the dealership and they said they fixed it. Don't know if it is related.
So here are the questions:
1. The slight bit of play at the tire does not seem right?
2. Should the tires both turn like that on the offroad when the diff is not locked via the locker switch?
3. Any thoughts on the clunk that got me heading down this path?
