Have you had a rear diff failure?
1 - 10 of 10 Posts
If you did, please answer these questions.
Year:
Make:
Model:
Build Date:
Trim (ie. X, S, SE, Off-Road):
Transmission (Auto / Manual):
Suspension Lift:
Tire Size:
Tire Make:
Tire Model:
Covered under warranty:
NOTICE: Any posts not directly related to the above info will be deleted.
Discussion Starter #2
Year: 2005
Build Date: March 2005
Trim (ie. X, S, SE, Off-Road): Off-Road
Transmission (Auto / Manual): Auto
Suspension Lift: 2.5"
Tire Size: 285/75R16 (33")
Tire Make: BFG
Tire Model: MT
Covered under warranty: Yes
Not an X owner here, but I"ll put my info in since its the same axle. Also, I had the locker on when the failure occurred.
Year: 2005
Model: Frontier
Trim (ie. X, S, SE, Off-Road): Nismo 2wd
Suspension Lift: AC 2.5" w/ AAL and 1" block
Tire Size: 265/75/16's
Tire Make: BFG
Tire Model: MT
Covered under warranty: Yes, after a long fight.
Year: 2005
Build Date: 7/05
Trim (ie. X, S, SE, Off-Road):S
Transmission (Auto / Manual): Manual
Suspension Lift: Not at the time
Tire Size: 265/75R16
Tire Make: BFG
Tire Model: AT K/O
Covered under warranty: YES @ 28,000 miles
Year: 2008
Build Date: 10/07
Trim (ie. X, S, SE, Off-Road): OR
Transmission (Auto / Manual): AT
Suspension Lift: None
Tire Size: P265/75R16
Tire Make: BF Goodrich
Tire Model: Rugged Trail T/A
Covered under warranty: Yes at 2500 miles
Year: 2006
Build Date: early 06
Transmission: AT
Suspension Lift: PRG 3"
Tire Make: BFG
Tire Model: All Terrain II K/O
Covered under warranty: Yes @ 27k miles
Year: 2006
Make/Model: Nissan Xterra OR
Trans: AT
Mods: Stock
Issue: Rear locker would not release so dealer replaced entire rear axle.
Year: 2007
Build Date: 07
Suspension Lift: No
Tire Make: Bridgestone
Tire Model: Dueler AT Revo
Covered under warranty: [email protected]
06 OR 6MT 130K... owner since 2019
Year: 2006
Build Date: ionno
Trim (ie. X, S, SE, Off-Road): Offroad
Suspension Lift: OEM
Tire Size: 32"
Tire Make:
Tire Model:
Covered under warranty: No
1 - 10 of 10 Posts
