1 - 3 of 3 Posts
I will be replacing my wife's rear brake pads and rotors and I can't find any thread showing the rear brake caliper housing bolt size.
This is for a 2006 Xterra.
I found the following:
- rear brake caliper bolt size (14mm)
- rear brake caliper inside bolt (17mm)
- rear brake caliper bolt torque (32 ft-lbs)
- rear brake caliper housing bolt size (?)
- rear brake caliper housing bolt torque (76 ft-lbs)
Checking out is somebody knows the rear brake caliper housing bolt size?
Thanks.
1 - 3 of 3 Posts
