Muzikman
I have never heard of making the ground wire longer. I have heard about making it shorter. I always ground as close to the device as possible with the shortest possible ground wire and I have never had a problem.
I agree with the shorter the better but you can not always find a good ground in a short distance from what ever device you are hooking up.
When I was still learning how to do installs,(well I never stopped learning lol) one of the guys in the shop had told me this was another trick to get rid of that whine noise I probably only did it 2 or 3 times and it does work. The short is if I remember right being longer helps absorb that whine.
In most cases centralizing all the grounds always worked. I learned really fast to centralize the grounds from the start. Also always run power, ground, and remote away from speaker wires and line levels inputs, you do not want to pick noise that way either.
USArmyX what happened to that whine?
