Did you install a new rack yourself?New or reman rack is needed there is a seal kit but there is a weird nut around that input shaft that takes a special tool that i could not find anywhere.
How’s the rack holding up? I read that you can remove from the passenger side and don’t need to remove the front differentialSee my post here: Rack and Pinion {{Clunk}} ?
The rack is holding up great, no complaints! And no leaks.How’s the rack holding up? I read that you can remove from the passenger side and don’t need to remove the front differential
Did you follow a how to when dropping it? Looking for one nowThe rack is holding up great, no complaints! And no leaks.
I read that too, and spent several hours trying to snake the rack out of the passenger side. I finally gave up, dropped the front diff (which wasn't that difficult at all) and it came right out and the new one slid right in.
I found one, doesn’t seem to difficult.. when you loosened the pinch bolt on the input shaft did it just pull out of the rack?I have a set of the factory service manuals. You may be able to find them online.
Swapped my rack last year. Here is a quick write up. This is what I remember doing so just use it as a reference.Did you follow a how to when dropping it? Looking for one now
