I am looking at a set of OEM OR seat covers. How hard do you think it would be to swap the seat covers out? I'm sure the back would be easy but I'm not sure about the fronts.
You know some secret I didn't discover! I tried to disassemble the back seats and didn't have much luck. The front are pretty easy, but the back is another story. MC
I looked again last night. It looks like the rear cushions are easy but the rear seat back may be a little harder. It appears that you unbolt the seat back then remove the cargo area trim (Somehow) from the back of the seat from there it should be pretty straight forward.
I've done it before on my previous vehicle - its not hard, but kind of like stuffing a greased pig into a sack. If you do it right then its easy. Turn the new cover inside out then start from the top and work your way down, making sure that you pull out all wrinkles.
