1 - 8 of 8 Posts
Alright, so I am pretty dumb when it comes to electronics and whatnot, but I think that I have a general idea of how I want to run my CB setup. How does this sound?
*Cobra 18WXSTII CB Radio With Weather Radio
http://www.walcottcb.com/product_info.php?products_id=518{44}566{45}559{51}673
*Firestik II FS (Hand Tune) Antennas 3 Foot Lengths FS3
http://www.walcottcb.com/firestik-ii-fs-hand-tune-antennas-foot-lengths-fs3-p-901.html
*Firestik - MK174 - Hood Groove Mini Kit
http://www.walcottcb.com/firestik-mk174-hood-groove-mini-kit-p-311.html
*Firestik SS34AH Combo. Heavy Duty "SS" Spring & Stud Mount
http://www.walcottcb.com/firestik-ss34ah-combo-heavy-duty-ss-spring-stud-mount-p-824.html
I want to mount it on the driver's side, in the groove of the hatch, but not on the hatch itself. I DO have the Shrock rear bumper (minus tire carrier) but no mount. Does this seem like a feesable setup? Thanks!
*EDIT*
Added the links, just as directed...still no dice. Not sure as to what's wrong.
i dont see a prob with the set up, just mount it right and u shoulod be good
With the SWR, I have heard from some people (not specifically X owners) that it is better to let a CB shop tune it for you, since they probably know more than I do about it. Is that an accurate statement? Also, how does that come into play if I do the actual install of the setup myself? WOuld I set it all up and then just take it to the shop to get tuned? I have also heard that it could damage the system if you use it un-tuned. True or not?
If you don't have any experience setting the SWR, heading to a CB shop is an option. You can get a inexpensive SWR meter at Radio Shack and follow the direction on the post above and set it your self. Running without setting the SWR will end up damaging your radio.
Mounting to the hood may present some grounding problems as the hood isn't a reall good electrical ground. -- Give it a try anyway!!
1 - 8 of 8 Posts
