1 - 6 of 6 Posts
I know this has been talked about but just want some advice for a new member before I order tires. I just ordered the pro comp 7089 and it will be going on a stock height 2008 S. I was originally going to just go with 265/75 but should I go with the 285's and trim the fender and melt or stick with the 265's and just do the melt? I don't plan to do a huge lift anytime soon and don't do hardcore 4wheeling either. Is it that large of a visual difference with the 285's over the 265's? Thanks in advance!
In your case, IMO, go with the 265/75/16 sense you don't wheel that much or hard, and Yes, there is a big visual difference between the 285 and 265 size tires! The 265/75 will do well when you need them and with a lot less headaches sense your not planning a lift anytime soon!
1 - 6 of 6 Posts
