You simply register, select if you'd like the image to be resized (always do), and upload.
When the photo uploads, you will be given a list of links to use on our forums.
Copy the bottom link and past it in the forums. Highlight the entire link and click the IMG tab just above where you are entering your text.
This will put special Image brackets around your link that will hopefully show up as a photo once you hit Submit.
________
Ipad cases
