AMPROAD Epic 1000 Portable Power Station 1000Wh
$500
direct from manufacturer in Ontario, Canada
Needs 10+ buyers
my experience:
I had the 300Wh unit for the past month, and I took it through several charge and discharge cycles with DC and AC charging and USB-C and AC loads.
Worked great.
I am a fan of the shape, I keep it behind front passenger seat.
if you are a casual user, go for the $180+ tax 300Wh version. It’s great.
Either unit has solar panel storing ability (which I don’t use). Or for my use, 100Watt DC charging at the same time as 65 Watt USB C charging (both in the car for me). That makes for a good recharge
If you are a power user like me, you will not find a better deal than $500 out the door, on a 1000Wh unit with tech support. (Texting preferred, I have taken advantage of that for info about charging while using loads)
I have done research for the past year and I haven’t found a competitor for my interest.
I will have an email/text contact when we reach a count of 10 buyers. Let me know in here or privately if you are ready to buy. Or just comment here about your thoughts on this and other power banks.
if you look at the Group Buy Forum history, we had a good run with Maxtrax tread boards a year ago.
$500
Amazon.com : AMPROAD Epic 300 Portable Power Station 300W, 300Wh Backup Power Supply with 4*LED Lights and AC/DC/QC USB Ports, Solar Generator for Home Use, Camping, RV, and CPAP(Without Solar Panel) : Patio, Lawn & Garden
www.amazon.com
Needs 10+ buyers
my experience:
Worked great.
