I love the width and look of the Pathfinder's step rails. I was wondering if anyone who does bodywork can answer a few questions. I know that the Pathy's step rails would probably be too long for the X. So, I was thinking about purchasing a set. Then, cut the step rails in half a modify then to fit for the X and relocate the mounting points. The step rails are made of what seems to be ABS plastic. When putting 2 pieces back together again (using bondo, I'm assuming or whatever) in order to make the Pathy's step rails shorter, how does the structural integrity change? Do you think it will be able to support the weight that will be incurred upon it?
