1 - 8 of 8 Posts
hey guys -
I just wanted to post a quick problem. Well, I recently installed the tralier harness with relays for my xterra and got that working but right after I installed the harness my passenger door lock and window controls don't work. I first thought is a fuse but I am not sure. does anyone have a diagram of the passenger door fuse and number so I can check or any other ideas.
Thanks, again
Andrew
There's no fuse for the door lock and window system, but there are fuses for the body control module, the BCM.
Do your interior lights still work? If so, a fuse is not the problem.
Otherwise, check fuse 18 first, then check fusible link g.
The interior lights do work and everything else seems fine. Does that mean I screwed up something on the install? I will check fuse 18.
Sorry, I glossed right over the "passenger" part... It's definitely not a fuse problem. If the BCM fuse had blown, there would be many more symptoms.
hey guys -
Thanks, again
Andrew
Hey, let me know if you found the answer. I just did the same exact thing and now having same exact issue.
1 - 8 of 8 Posts
