So I'm trying to figure out what my next step is.
'05 was sitting for a bit at the beginning of our stay-at-home time. Two or three times it had to turn over for a little while before starting. I started getting the SLIP and VDC light staying on, and picked up a p0340 "cam position sensor bank 1 (passenger)" sensor code, so I replaced the sensor (this is the straight sensor). "Fix it Felix's" youtube video helped prepare me for how annoying it would be to access the darn thing, made me want to have skinnier hands and arms. I also cleaned the throttle body and did the re-learns at the same time, just because I was in there and had some time.
The starting issues went away, everything seems to be running fine, idle is nice and low now (650 rpm) after the throttle body cleaning and re-learns. But now I'm getting a p0011 code -- "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1). The only other thread I've seen that included an 0340 and a 0011 was kylejoe, but he got the 0011 first then the 0340. Most threads regarding 0011 mention a whole host of possible problems, but the sensor is NOT one of them (that I've seen).
Where to start troubleshooting? There are a lot of other threads on these topics, which I have plumbed thoroughly (1,2, 3 for example). But despite the plethora of information, I'm still stumped about what to try first. Bit overwhelmed by all the possible problems that may be causing it.
The sensor I put in was inexpensive, definitely not OEM. Should I suspect that and replace that again first? I don't want to go replacing the IVT solenoids unless it's necessary. And I'm taking a long offroad trip to middle-of-nowhere utah next week, so I'm worried about getting stranded.
Advice appreciated! thanks
Matt
Matt
