So I posted a few months ago about a over heating problem I had while in Moab... took it to the dealer and they said my overflow tank was filled above the max line. They drained it and filled to the proper level. I drove my X home with the A/C on and it ran fine.
Well, with the 100+ degree weather we have now in Las Vegas the X is overheating again. On the freeway this morning I had to pull over and let the X cool down. Outside temp was around 103 and my temp gauge was almost peaked out. A/C was on, I was driving approx 70mph for a few miles on the freeway when this happened. When the A/C is on it seems to run hotter than normal and most of the time it peaks out the temp gauge.
The electric fan does come on, at least everytime i check it is on. Coolant levels are normal and no visible debris in my radiator. Nothing is blocking the front either. Has anyone experienced theirs running hot with the A/C on?
