1 - 2 of 2 Posts
you'll need to find a cross beam in the roof (often, you'll find one after removing the overhead dome lights), cut a hole in the headliner beneath that cross beam, cut your dvd player's plastic shroud if you're mounting the unit on the curved part of the headliner, bolt the dvd player's mounting plate onto the cross beam, run your wires up the A or B pillar, connect your plugs, and then mount the unit to the mounting plate.
straight forward install....but not the easiest to get proper results.
1 - 2 of 2 Posts
