I have a 2011 Xterra S ran fine then I parked for a couple weeks but it wouldn't start or even turn over. It was cold so I assumed the battery was dead. I charged battery and even tried Jumpstarting with no luck. This is what I have replaced. Battery, Negative battery cable, fusible positive connection, IPDM, all relays pertaining to starting, ignition, etc. Here is what happens or what I see when trying to start. When I turn ignition to on dash lights up like a Christmas tree. The service engine light and security light are lit and solid. Many other warning lights are lit as well. The cooling fan starts running and the headlights light up. When turning the key to start no lights flicker or dim, the starter relay in the ipdm clicks once. I cannot turn on or off the headlights with the switch. The wipers won't turn on. The hazards and blinkers will physically flash but do not light up on the dash. Also the radio will not light up or turn on. I've jumped across the starter and it will spin over so there is power to the starter and it is not froze up. Any suggestions would be greatly appreciated because I have read and watched videos for weeks along with trying different parts and such.
