1 - 16 of 16 Posts
ok been searching through the threads here and remember there was some discussions on the possibilities of replacing the stock OR/ P4x lights to LED light bars like the rigid duellers or the 2x2" that NYX sells in his GB in the air dam
has this been done? I can't seem to find that thread where it was being discussed.
Discussion Starter #13
they wouldn't work with the stock light adjusters( by the way that the stock lights are held into the mounting brackets ). but you probably would be able to space the bottom attachment bolts to be able to adjust the up/down
on a similar note, has anyone run a 40" LED bar off of the stock OR/P4X roof light wiring? i'm looking to get a 40" bar from NYX's group buy and wire it to the stock roof light setup, but i think it'll only handle 15 amps. I guess i could wire up a separate circuit and relay and just have the roof light harness power a relay under the air dam but i'd rather not have to go to that much trouble if i don't have to.
1 - 16 of 16 Posts
