1 - 10 of 10 Posts
i know there was a post on this
about the Optima Yellow Top
i need to get a Optima battery
but ours is reversed
and i remember reading a topic about this in the past
of where i can find it
does anybody know where its at or have any information on itt
get a red top if you want it for all around use, yellow top only if you're going to use a lot of equipment without the engine running.
i think there is a Optima battery in reversed
so your saying i would be better off with a Red TOp then a yellow top
Because i have alot of accesories on my car..
like stero, lights, and more stuff..
and i wanna add fog lights later on..
I have installed the d35 on my x here are some pics
I know a few people have said that the optima batteries are not as good as they used to be, but so far I have had no problems..
is da D35 the one that is made for the Reverse Terminals..
is dis the Deep Cycle Yellow Top
yes that is a d35 with reversed terminals BUT... it is a smaller battery. the d34 is the normal size that SHOULD be put in the X. but no d34 reverse terminal batteries are made anymore (in the yellow top)
would da d35 still do the same as the D34 tho..
because i have alot of accesories on my car and stuff..
So they dont have a Deep Cycle in Reverse Terminals..
just get the "non reversed" terminal battery and do the battery mod to it. Everything should work out dandy! I was the one who originally posted the battery mod and nothing has gone wrong with my X so far. Also if you want to check out Exide XDC batteries they are very similar to the optima yellow top (but you will have the same installation problems).
Here for battery: http://thenewx.org/phpbb2/viewtopic.php?t=2509
1 - 10 of 10 Posts
