One-Stop LED Conversion and Install How-to Shop
119693 Views 240 Replies 83 Participants Last post by  rm975
Hi, I am Chase and I am an LED addict. During my addiction I have been getting a lot of questions about my setup; which size lights are the stocks, what size LEDs do I need, where to get them, etc. Thought I would make an all-inclusive type deal for all such queries. Next to the specs is the link to the V-LEDS online store w/ examples, prices, etc. So, here goes...
Front running/turn signals
3457 (amber, and are interchangeable w/ 3157)
http://www.v-leds.com/Shop/Control/...1/field/1/page/1/refinableEmittingcolor/Amber
http://xterramods.summitdesign.ca/index.php?main_page=product_info&cPath=8_45&products_id=54
http://www.superbrightleds.com/tail-brake-turn.html
http://autolumination.com/3157_3156.htm
Rear turn signals
3156 (red)
http://www.v-leds.com/3157-3156-LED/Red-LED/sc122275-1-2//page/1/checkForLanding/true
http://xterramods.summitdesign.ca/index.php?main_page=product_info&cPath=8_44&products_id=50
Tail lights
3157 (red)
http://www.v-leds.com/Shop/Control/...481/field/1/page/1/refinableEmittingcolor/Red
http://xterramods.summitdesign.ca/index.php?main_page=product_info&cPath=8_45&products_id=53
License plate
168 (white)
http://www.v-leds.com/Exterior-LED/License-Plate-LED/sc253988//page/1/checkForLanding/true
http://www.superbrightleds.com/mini-wedge.html
http://autolumination.com/194.htm
Reverse lights
921 (white)
http://www.v-leds.com/Shop/Control/...1/field/1/page/1/refinableEmittingcolor/White
http://autolumination.com/906.htm
Front sidemarkers
194 (amber)
Dome/map lights
DE3175/3175 (several color choices)
http://www.superbrightleds.com/festoon.html
White - http://www.v-leds.com/Interior-LED/DomeMap-LED/White-LED/HID-WHITE-9-LED-DOME-p4481130.html or http://xterramods.summitdesign.ca/index.php?main_page=index&cPath=8_49
Red - http://www.v-leds.com/Interior-LED/DomeMap-LED/Red-LED/tc122439/
Blue - http://www.v-leds.com/Interior-LED/DomeMap-LED/Blue-LED/tc122437/
http://autolumination.com/festoon.htm
Load resistors
These are needed to stop the rapid-click turn signal from installing the turn signal LED bulbs.
http://www.v-leds.com/BlinkerWarning-Fix/Turn-Signal-Fix/6-OHM-50W-2-BULB-LED-p4783296-1-3.html
http://xterramods.summitdesign.ca/index.php?main_page=product_info&cPath=51&products_id=49
These are specs for my 2005 but I am 99.99% sure they are the same for all models '05+. You use the same size/classification as the stock lights as you do for the LEDs! For example, the reverse light bulb is 921 and requires a 921 LED bulb - too easy.
Stock bulb specs
---LED-Related Threads---
My LED mods
VisionX LED strobe pods
Interior domes
My first reverse lights (HID white 6-LED bulbs)
Upgraded reverse lights (HID white 19 M-SMT 8W high power bulbs)
High power LED reverse lights
My "Rev" mod - rear cargo LED strips
LED headlights mod
M-SMT 92-LED rear running/brake lights (my build page, post #256)
PaulXyZ's LED center armrest mod
PaulXyZ's LED festoon thread
DragonPlayboy's LED mod
CynicRoute's LED store
Rev's rear cargo area LED mod
Rev's LED's on the floor/cup holder/rocker switches mod
Rev's engine bay lights
XJ-TERRA's LED clearance lights mod
Chug's rear cargo area motion-activated LED mod
CrazyEye's gauge cluster LED mod
---How To Install Interior LED Dome Lights---
Front map lights, HID white 9-LED bulbs from V-LEDS (http://www.v-leds.com/Interior-LED/DomeMap-LED/White-LED/HID-WHITE-9-LED-DOME-p4481130-1-2.html)
The housing simply pops out, like so.
Next, unplug the wiring harness.
Then you will need to remove the outer plastic casing by popping off the four gray tabs along the outside.
And also pop off the clear plastic clips holding the covers on.
This is not what the stock bulbs look like, these are the 12-LED strips from Cynicroute and his XterraMods site.
These are the 9-LED bulbs replacing the 12-LED strips.
Remove old bulbs and pop in new LEDs. Be sure to test fit by plugging wiring harness in after inserting new LEDs, they are polarity-specific and if they do not turn on then they simply need to be turned around!
Pop the clear plastic covers back on as well as the outer gray plastic housing.
And, voila! Let there be (LED) light!
---How to Install Rear Passenger & Cargo LED Dome Lights---
These LED's are the HID white 16-LED bulbs from V-LEDS (http://www.v-leds.com/Interior-LED/DomeMap-LED/White-LED/HID-WHITE-M-SMT-16-LED-p5767433-1-2.html)
Much like the front lights... Use a screwdriver or knife tip to pop off the plastic cover.
There are two screws to undo (phillips head).
Pop out housing and remove wiring harness.
Remove old bulb and insert new LED's.
Again, be sure to test them (re-plug the wiring harness in before re-assembling everything.) to make sure they do not need to be swapped around. BUT, if you test them and you see this, a very faint glow...
DO NOT WORRY! I thought I had duds (again) but once you screw everything back in it lights up as normal. The screws must act as a sort of grounding or something. It should look *bling* like this once it is all back together.
Reassemble the housing (plug the wiring harness in, screw the two screws back in, and pop the plastic housing on). Here is your finished result.
The same goes for the rear cargo dome, exact same directions for install as rear passenger dome.
---How to Install Resistors---
When swapping out your front AND rear turn signals for LED's, you will need to install a 3 ohm resistor. If only doing the fronts or only the rears, a 6 ohm resistor will do the trick. This will solve the blown fuses and rapid-blinking issues. Since there is more free space to get your hands on to the necessary wiring in the rear taillights, I recommend going this route. Very simple install - wire tap one end of the resistor to the black negative wire and tap the other end to the green positive wire. Should look like this...
---How to Install Front Side Marker LED Lights---
These are the 194 amber LED bulbs from V-LEDS, here:
Pop open hood and go to light housing area, the bulb is very noticeable and accessible, seen here on the bottom right.
Twist counter-clockwise and pull out harness.
New LED bulb.
Old (L) vs. new (R).
Insert new LED bulb (same deal goes; if it doesn't light up then just pull out and re-insert the other way).
Re-insert new bulb/housing by twisting clockwise and, voila!
SMT X5 high-power side-markers
http://www.v-leds.com/Exterior-LED/...r-LED/2-AMBER-SMT-X5-HIGH-POWER-p6640085.html
New SMT high-power bulb compared to old standard SMT bulb
Installed pic
Front running/turn signal LED
After a long time of blowing fuses and/or rapid clicker, I FINALLY realized my problem... or X's require a SACK Type front LED bulb. You can get it here, like I did - http://www.v-leds.com/Exterior-LED/Turn-Signal-LED/Amber-LED/V-LEDS-AMBER-60-SACK-p6204431.html
Installed pics
221 - 240 of 241 Posts
i believe the climate control lights are led from factory so its weird that they have "dimmed".. hmm
I swore I saw a write up on someone that had changed them all over so I'm not sure, I don't really want to venture and take it apart unless I know whats behind it lol
deltaphi26 i think is the mans name on here..he has done his gauge cluster leds and some other pieces. he may have insight
$16 for a 3175 dome Bulb, that's a hell of any increase over the last ones I got from them @$2 a piece !!!
Here is a photo to help explain
This happened to me after my car was broken into and they ripped out the whole center console piece. The shop just replaced the whole unit, they didnt attempt to take apart that whole system to replace a broken dial and light. Of course it could just be them going after the insurance money but they made it sound like taking apart that whole unit wasnt worth the hassle for the two parts.
Anyone swap out the reverse light bulbs recently... If so which ones did you go for ?
Just did mine with these: http://www.ebay.com/itm/231292258958?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Fit right in, no drama. Huge improvement over the stock bulbs, and the price is right.
So just to clarify, I need SRCK bulbs for the front turn signal on my 09 Xterra Off Road?
so to be clear.... 4 of these will do the trick for the interior maps, dome, and trunk?
VLEDS
I have a couple questions about the LED replacements:
1. For the RED brake lights I have been told that because the OEM incandescent bulb is a double filament for tail/brake functions that an LED will not work. Is this correct and if not how how do I replace the OEM brake lights with LED's
2. for the colored lights red & amber do you have to use a colored LED?
I've replaced my interior bulbs with blue LED's and I like them. I'd like to change out the others as well.
VLEDS
I know its been a few months since you posted this but wanted to confirm that you are correct. I just purchased 4 3175's and installed them yesterday. They work great!
Hi
I'm looking to upgrade my fogs and reverse lights, and am looking at vled and superbrightleds websites and notice a huge price difference.
Vled 140 dollars
HIGH OUTPUT WHITE 360° 15 LED 921 - 921 - Shop Bulb Number
H11 H8 H9 H16 LED HEADLIGHTS HIGH OUTPUT LMZ PLATINUM 25W
Superbrightleds 62 dollars
https://www.superbrightleds.com/mor...-led-tower-miniature-wedge-retrofit-lan/3305/
https://www.superbrightleds.com/mor...smd-led-daytime-running-light-led-tower/1278/
I'm assuming vled applies more LEDs per bulb, which is why they are more, as well as they seem more branded than superbrightleds. Are they worth the 125% cost increase tho? Any input is appreciated.
FYI for my 9007 bulbs I plan on going with piaa xtremewhite because I would rather have a dot headlight.
Thanks
Hi
Vled 140 dollars
Thanks
I would visit Diode Dynamics page here on the forum, they respond very quickly to post about led's, they should set you straight.
  • Like
Reactions: 1
Thanks for the quick response
I think I selected the wrong led for my fogs, replacement bulbs vs conversion kit. The conversion kit is 100, therefore the price difference is 112 to 140.
https://www.superbrightleds.com/mor...s-conversion-kit-with-built-in-fan/2115/4803/
I'm pretty happy I came across this thread. The tip on using a single 3ohm resister for each side was great. I didn't know any better at the time I did my Frontier. I ended up putting in two 6ohm resistors per side.
I went with Siriusled's off of Amazon. These are what I used in the Frontier with good results.
I installed LED headlights a couple of weeks ago to match the color temperature of my off road lighting (5000k). These bulbs fit without modifying the X in any way: https://www.amazon.com/gp/aw/d/B07NN4J9MX?psc=1&ref=ppx_pop_mob_b_asin_title
I also replaced the reversing lights with these, and they are fantastically bright: https://www.amazon.com/gp/aw/d/B0728DYR9H?psc=1&ref=ppx_pop_mob_b_asin_title
Just installed these interior replacements. Impressive.
  • Like
Reactions: 1
