Ok, so after letting someone know how easy an oil change was in my old jeep in another post...I crawled under the X today to change out the oil. Hmm. Took me a minute to find the filter, check, then to locate the drain plug, check.
My question is, how do I get to the drain plug, should I remove the skid plate that is there (that seems like more than I need to do)?
Also, if I don't remove it, where does all the oil drain out at, or where should I put the pan?
Maybe I should have looked before being over confident. :cwm10:
