1 - 20 of 33 Posts
Date is officially set: Saturday November 30, Hartland, VT. Post up if you want to come up and get ready for winter with me/
-Dropping all skids to grind and repaint.
-changing the oil, front diff, and t-case fluids.
-grind and repaint sliders.
-figure out why my fogs don't work (if I don't do this sooner.
- putting on my winter wheels/tires.
-if I can get all the parts together, which is unlikely, I need to replace the fuel sending unit.
If anyone wants to come up and help or do anything to their trucks, I'm down to have people. Heated garage, plenty of space etc.
Noah, Ive don't the FSU change, its actually really easy. I will try and make this to help you with that. Also I am going to sticky this till after this happens, just keep it updated please.
The parts were a little under $100 if I remember correctly. Unless you're having issues with the pump leave it. I think I changed the fuel filter when I did the FSU.
Yeah and then I'm going to attacked with why I should move to VT.......
If you need the parts I MIGHT be able to get them at the local stealership for a little under retail.
16th works for me.
Could do the rear diff breather mod, maybe change over the snow tires.
Anyone have a front shrock or hefty i can measure?
I could do either date.
I want to do the rear diff breather mod also, and radiator bypass as well as a few other minor miscellaneous things.
1 - 20 of 33 Posts
