1 - 2 of 2 Posts
I have an odd either rubbing or grinding noise coming from what sounds like the front drivers side. it only happens when I turn the wheel to the left about one full to full and a half turns on the steering wheel. If I turn it all the way or less than 1 full turn I don't hear the noise.
I'm running the AC coil lift and factory sized BFG AT's.
So far I've looked around the wheel well and don't see any signs of rubbing. I have not taken the wheel off yet but was looking for ideas first.
Does anyone have any suggestions on what to check?
It's not your inner fender is it?
Check your swaybar connectors.
Brakes?
Something stuck in your spindle and rubbing on the CV joint when turning?
1 - 2 of 2 Posts
