1 - 5 of 5 Posts
I have the 0430 code and it's hindering my gas mileage. I'm trying to make a road trip happen and it would definitely benefit to spend 15-30 bucks on it now so I can have normal gas mileage for the trip until I can buy a new cat. Would this work the way I hope?
how many miles on your truck? do you click your gas cap 5 times at least? do you have a rotten egg smell from exhaust?
02 sensors have to be checked to see if they are working...... you might have a leak somewhere......
120k, never, idk. Doesn't a bad o2 throw a different code? Let me simplify, will getting rid of the code restore gas mileage? Anyone with experience with these o2 extender things?
you should always click your gas cap at least 5 times.... this can also cause that code
the o2 sensors don't always throw a code.... mine did not throw a code, just looked at the diagnostic reading for them.... they did not have a short pattern up and down like a sewing maching stich... they where spaced out... I replaced them with oem front o2 sensors.
with that code I also went to muffler shop to have them inspect the flow out of exhaust just to make sure it was not a cat replacement issue.
cheap gas can also throw that code..
I would start with looking for a leak.... then do the battery disconnect and also put good gas and click your gas cap 5 times when closing.
but the most efficient thing is to have an auto electric place plug the computer and read the activity for the 02 sensors..... before buying anything
Just having the code shouldn't affect mileage, the cause of the code, which could be a partially plugged cat that is restricting flow, may be affecting mileage. I don't think clearing the code without fixing the problem will get you far.
1 - 5 of 5 Posts
