After digesting all my searches for perfect way to do front lift i came to these conclusions
Preloading springs is what lift comes from, moving "good ride" zone toward firmer tension range of the spring, away from factory designed ride
All aftermarket lift springs come with shocks designed to work together and mixing leads to variable results that may or may not result in desirable ride on or offroad or both
Looking at aftermarket springs they are obviously designed to work at higher than stock springs tension hence the ride is firmer or harsh
If i add a spacer above spring the ride will stay the same(or almost) but l will achieve lift according to thickness of the spacer. So if i add 1/4spacer lift will be 1/2" ?
My street/highway to offroad driving ratio is about 75% to 25% hence comfort is important. Perhaps my "perfect ride" can be achieved by Bils 5100 set at 1" lift plus 1/4" spacers to achive total 1.5 springs? Of course i do have adjustable USAs so camber setting is not an issue
