1 - 20 of 123 Posts
Intro Comments: All work was done by myself...
Username: NoahSki
Truck Name: WARHAMR
Year: 2012
Trim: Pro-4X
Color: Night Armor
SUSPENSION:
- NissTec 2" front spacers
- NissTec camber bolts
- PRG variable height shackles
- Rear sway bar removed
FLUIDS:
- Mobile 1 5w30 full synthetic oil
- Mobile 1 75w140 rear diff fluid
- All other fluids for now are stock
ARMOR:
- Ballistic Fab rear diff cover
- Stock Pro-4X skids
- Insain Fab radiator skid plate
- Insain Fab front plate bumper with 22" lightbar and quad 3" led pods
- Insain Fab rear bumper with tire carrier, CB antenna mount, hi lift mount, and rotopax mount
WHEELS & TIRES:
- 5 x Stock Pro-4X wheels sprayed with raptor liner
- Goodyear Wrangler Duratrac 285/75r16
- 2" wheel spacers all around
ENGINE/PERFORMANCE:
- Volant CAI
- BullyDog tuner (50 state legal)
- Doug Thorley shorty headers
- Optima Red Top battery with upgraded terminals and wiring extensions (positive and negative)
- 100 amp in-line fuse for Blue Sea fuse box
- XTP IMS
EXTERIOR:
- Custom aluminum grille (sprayed with raptor liner)
- 2" body lift from Jersey Parts
- Poison Spyder hood louver (riveted on and sprayed with raptor liner)
- All plastics sprayed with raptor liner
- Tail lights blacked out
- Gobi rear passenger side ladder (shrockworks compatible with red backplate added behind letters)
- CravenSpeed 338 Lapua antenna
- Removed rear Nissan burger and installed US Flag emblem with satin black backplate
- Nissan 7 Pin tow harness
- Roof rack blacked out
- USA bottle opener mounted on front bumper
- American Flag eagle front plate covering winch fairlead hole for now
- 4X 3/4" recovery shackles with red isolators
LIGHTING:
- 40" curved LED LIGHTBAR with 3 isolators on InSain Fab mounts (modified to stop roof vibration)
- LED pods in the rear corners
- 30" single row LED lightbar on custom rear mount
- 55w HID headlights with 6000k bulbs (high and low beams)
- All interior roof light bulbs switched to LED
- LED reverse light bulbs
- 20" combo lightbar in front bumper
- 4x 3" LED cubes in front bumper
INTERIOR:
- Kenwood DNX7190HD head unit
- Nissan pet divider
- Raingler large ceiling net
- Bungee chords on the roof to hold fishing poles
- Gun rack's on the back to the front seats with ammo/game call pockets
- Factory leather
- Home made molle panels for both back windows and hatch
- OTRATTW 6 switch panel next to shifter
- OTRATTW 4 switch panel next to 4wd selector
- Blue Sea fuse box bolted to factory subwoofer housing
- Blend mount above rear view mirror for Bullydog tuner
- Craftsman toolboxes under rear seats
- Dual USB port where factory aux jack was
- Pro-4X white face gauges
- Grey and red leather steering wheel cover
- Rear cargo hatch hook
Discussion Starter · #14 ·
Nope no whistling at all. Water gets in but it's not an issue. Our engine bay isn't sealed anyway. Haven't had any problems with water and here in coastal Georgia we get some pretty heavy rains. Pretty much with modern engines as long as you're not hosing down the alternator while the engine is running it will be fine.
Discussion Starter · #17 ·
Depends on your plans for your rig in the long run. If you plan to run 35's ever then absolutely. If you want more body clearance or want sliders then yes since sliders have to be modified if they're not for a BL.
As far as I'm concerned, if you widen your stance to compensate there is no downside to a BL. It's not too hard to install (did mine in 2 days by myself taking my time) but you get the lift and clearance for the body and it's cheap.
However it does nothing for articulation or actual clearance for your lowest part (rear diff) but all together I would recommend a BL. Getting ready to do one on my brothers x here soon
Senior Member - AKA TK-421
the biggest thing for me is i have a MT and idk how i feel about the shifter being 2' shorter haha.
1 - 20 of 123 Posts
