1 - 5 of 5 Posts
I recently purchased a new radiator and a second cooler. I have completed the bypass mod and installed the second cooler. I have also replaced the OEM radiator with an aftermarket.
My question is this, with a new radiator installed would it be better to reverse the bypass and go back to the original setup?
I also flushed the whole transmission. No signs of strawberry milkshake.
If you have replaced the radiator, then you can go back to the original setup and regain the cooling capacity of the transmission cooler in the aftermarket radiator.
I went back to stock setup once I replaced.
1 - 5 of 5 Posts
