1 - 8 of 8 Posts
Hey guys, need some advice...
I recently purchased a 2011 X. Overall great experience so far! Upon buying the vehicle I removed the running boards and mudflaps. I must have over tightened the screws because after a long trip I noticed all of the mounting holes had cracked. Any ideas how I could quickly repair these? Am I going to be forced to replace the liners?
132417
JB Weld Plasticweld epoxy putty.
Score (scratch) the areas which will be glued to provide a surface which the epoxy can be bonded .
I would bond the area which is separated and epoxy a plastic patch on the back side(body side) which will help ensure long term integrity.
I honestly don't think a glue will last long term. If you do want to try one the best I have ever found was a 2 part epoxy - made for boats Bob Smith Industries BSI-201 Quik-Cure Epoxy (4.5 oz. Combined), Clear: Amazon.com: Industrial & Scientific
You could find another piece of plastic you could rivet it into the area and epoxy the original and patch together - that might hold for a while. But thats a lot of work.
I would get some from a junkyard. If you have a pull a part near you they likely won't charge much. There not a part many people are looking for.
I've been waiting to see some cool custom wheel liners for our trucks similar to what jeeps have available:
Someone could make a killing welding some custom aluminum well liners and selling them to the public for xterras and frontys.
132448
Hell, with some cardboard and scissors you could weld your own.
That would be awesome! I just use washers on mine. It works, might not look the best, but I need to clean up my fender trim job anyway.
  • Like
Reactions: Brunnie
I'd second this- It doesn't seem like the cracks will really need much reinforcement to keep the liners in place. Some large washers should be fine (esp. rubber ones if you can find em).
I had to replace the fender liners on my 2011 as well after I bought it (they were chewed-up in the front and rubbing the wheel). As someone else mentioned, they really aren't that expensive and it's a straightforward install. Try washers, if they don't do it for you functionally or aesthetically just throw new ones in.
1 - 8 of 8 Posts
