OK, so i got my 285/75/16 dueler revo's mounted on the black 16x8 cragar's and i put the 1.3" spacers on, tightened them down as best I could, and then went to put the rims on, i started with the rear driver's side first, and heat gunned and bent in the front drivers side wheel well plastic with a dewalt battery first so it'd cool while I was working on the rear. I'll post some pics now, I wanted to get this note up first. two concerns: do I have enough clearance here? I'm concerned, there's probably about 2" or so all around the tire and I don't want to hit a big bump and mess something up bad...
also I think I stripped one of the lug nuts, because it screwed on and off like normal, but when i went to torque it down real good, it just kept screwing down without stopping (DAMMIT!) see pics (in a sec) so if that is the case, would the car be OK with 5 solid lugs and 1 weak one until the guy can send me a new one, or do I need to abort before doing the other three wheels?
Thanks!
Thanks!
