1 - 11 of 11 Posts
Of course, I took it to the dealer (still under warranty).
The first service writer was puzzled and thought maybe it was on the outside.
"Maybe the recon guy can do something about that."
When I came back to pick up the Xterra, the other service writer told me:
"We ordered you new headlights."
It does not cover the whole inside, just some large random areas.
Any one else have this problem?
sounds like bad seals. condensation. i have not had issues. but had a tail light replaced under warranty for inside condensation.
No Condensation
I know condensation.
They do too.
Dry as a bone.
Always has been.
12K mi. on the truck.
I would if I could.
pictures would help :)
Yeah.
Unfortunately, I am not a good enough photographer to capture a light haze on a clear object in front of a highly reflective surface.:dontknow:
It is hard enough to see from 6ft. with the naked eye.
It is not bad enough to visibly diminish the light output.
I did not notice it when it was new.
I saw it after a year or so, but I might have just missed it before.
My has a spider INSIDE the top of the headlight. Didnt get temp gauge or heated mirrors but got a headlight spider
QUOTE=PA PRO 4X;1324994]wow. dont know then. this could be a first. could have been bad from the factory?[/QUOTE]
My fog lights had the same haze on the glass. I just pulled the bulb and used a shop rag and screwdriver and cleaned it out. If the dealer is giving you new headlights, bonus!
That's what I figured.
As long as it is under warranty, I let them make the call first.:thumbup:
[/QUOTE]
i also had a headlight spider. in the pass side in the bottom. little white spider.
1 - 11 of 11 Posts
