New Molles:
$75 shipped
includes 4.2lb Molle from 14gauge steel, may have some warping because of the Plasma cutting
includes 2 L brackets, 2 holes each, self tapping steel screws (put your own metal on the other side of plastic), 2 bolts + washers + nuts
(includes shipping, unless you're somewhere outside of 48, then a little more)
Issues:
1)
holding the bolts on the other side of Molle is not the easiest thin, I am considering nutserts pressed into the L bracket, so that your bolt goes through Molle and then on the L bracket are 2 nutserts into which your bolt goes into (no need for nuts or holding them).
I need enough interest for that first, it's a nice have if you anticipate off-on activities. It was fine for me the first time, but when I took it off, painted it, organized it and then tried to put it on (with many Molle bags attached), I sure wished for nutserts!!
Nutserts=rivets=rivnuts... like how the roof bolts screw into the roof with nutserts
Are the nutserts worth it to you for $5 extra?
2)
extra L brackets..... still working on a design
I drive on highway with open windows and 80mph and off road and nothing rattles but I see vibration on the passenger side (can't see driver's side but that side is heavier and has a lot more airflow blocked. The only thing that rattled was loose aluminum carabiners without anything on them just hitting the Molle in the airflow/road vibrations (on passenger side).
Ideally I would add 2 L brackets on each side (total of 6).
Everyone wants lighter Molle...... this is 4lb..... 11gauge would be double the weight at 9lb.... but lighter means not as hard. And lighter should be secured more if you're concerned.
Delivery timing:
Usually within a week but they come in batches, so earlier pay gets the Molle sooner.
Customization:
possible, if you want it to say something else (non offensive) instead of roXterra, or you want a graphic in part of the Molle instead....... bigger change, bigger cost
Powder coating:
Only if there are 5 at a time, same color..... In between the 3 powder coaters, Molles are the hardest to juggle with price/color/time-to-complete
Or spray it yourself, the hardest is waiting for paint to dry!! And overspray, watch out for overspray, start before and end after the object, lighter coats, less is more.
I think I answered all questions for the past week.... here and in private conversations? Let me know if you're waiting for my answer...
