401 - 413 of 413 Posts
FOR THE WIRING MOD.....
You will need to access the Wiring Harness at the Differential Lock Control Unit (DLCU). It may be easier to do this by removing the Driver-side Door Seal and the Knee Knocker Panel under the Steering Column.
Perform the changes on This Schematic. Due to new security standards at Google, I may have to grant access. It's been hit and miss whether I have to do this. Operating Instructions and Warnings are on the Schematic.
It allows anytime engagement of the factory installed M226 eLocker in 2HI and 4HI, without the 4 mph limit, without the associated warning lights, extra switches, and extra wiring of the 2005 Off Road Magazine / "Austin Mod". You will still use your factor Diff Lock switch and have indication on your factory Diff Lock indicator.
FOR THE PLUG N PLAY MOD.....
It installs in under two minutes, or as fast as thirty seconds (per some reviews).
It consists of locating the Differential Lock Control Unit (DLCU), near the hood release on Xterra's and Frontier's, near the rear bulkhead near the jack on 2nd gen Titans (not compatible with diesel Titans), unplugging the factory wiring harness from the DLCU, plugging this unit into the DLCU, and plugging the factory harness back into the included unit. Included instructions here.
This modification gives you the ability to lock the rear differential anytime as with with ARB Air Locker and Eaton E Locker. If you are uncertain about when to lock the differential, refer to the factory parameters of 4LO and under 5 MPH.
ENGAGING THE LOCKER UNDER THE WRONG CIRCUMSTANCES CAN LEAD TO DRIVE TRAIN DAMAGE
The price is $130, shipping included in price to lower 48, USPS Priority Class, including tracking information.
Tried accessing ths thru Google account but no go. Can you fix that or tell me where I can buy the kit Please?
Discussion Starter · #404 ·
Google changed some security settings on those shared files. I have to approve access on a case by case basis, per google. I haven't denied anyone access who has asked. Go far enough down the rabbit hole to request. Elsewise, PM me for the plug n play module.
If you still have the plug and play modules for sale I would love to get on the list. I just joined so can't PM you. Thanks
2007 Xterra OR
Add me to the list, please. This will make life so much better. Denied PM requirements.
A million thanks!
