1 - 11 of 11 Posts
I am considering mounting a 3 gallon rotopax on the bulge of the tailgate. Has anyone done this. Wondering about mounting strength and strut power.
Here's a relevant thread:
If you do it right, could probably work ok. I prefer mounting the fuel cans to the roof rack.
Oh ya good point, here's the etsy listing
Ouch. Im sure its a great product and I like the idea but its out of my budget. Thanks though, I do dig it
Side mounting Sherpa:
$425 in raw aluminum, powder coating available. That's the 3/16 "deluxe looking" thick aluminum.
For about half that, I have several 1/8 thick panels, thinner, but it only matters if you already saw the 3/16 inch version, both work.
These 1/8 inch thick panels are "prototypes", they have an extra hole or 2, and the outside contour of the main panel may be different, L panel an inch longer.
They are painted, but need new paint due to the on/off mounting. Re painting would be up to you.
Driver side and passenger side.
All have Rotopax (square) holes.
3/16 is in the first 2 pictures here:
This picture shows the Rotopax 4 square hole pattern, left in use, right unused.
2015 Pro 4X
I fabricated a removable mounting system to hold (2) 2 gallon rotopax rigs. With an extension you can double the storage. Bolts on to the Heps Design roof rack. Also built one for treads recovery boards. Used them dozens of times wheeling in the mojave desert.
135760
135756
135757
135758
135759
2011 Pro-4X
2010 Xterra S
That looks great! Are they difficult to access when they swell from changes in temp or altitude?
2015 Pro 4X
Not at all. And I go to extreme temp changes places... I just vent at least once a day when in use. Because my X is a daily driver, I only use when adventuring. Takes me literally 5 minutes to install/remove.
1 - 11 of 11 Posts
