1 - 12 of 12 Posts
like skateboard long boards? God I hope there aren't motorized SUP boards. I'm not going to sleep well tonight now...thanks haha
TNX Veteran
No, but I was behind one in traffic on my motorcycle the other day. He was going in between stop lights at about 20mph in the city. At every stoplight he would filter to the front. Was in the middle of the road. Wasn't sure if I should pass or stay behind...
Longboard skateboards are a blast, still have mine from the '90s. I will agree though I'd probably hurt myself badly on a motorized one. Does anyone know offhand how they're controlling the speed? (Since I don't see a cord anywhere)
What happens if the battery in the remote dies when you are doing 20 MPH?
"The Tomahawk Electric Longboard uses the latest in electric skateboard technology. Its hi-tech rechargeable remote control allows you to control the board's every move with the touch of a button."
I've seen some guys on campus with these, and I've also seen one get hurt badly when he went too fast on a mild hill with the motor. I'd take a traditional skateboard (or longboard, same thing) over one. If you just really want to avoid pushing you could always look into what's called land paddling, though I must say it looks a bit dumb but it could be a blast, I can't say. Bottom line, I'd stick with a regular board! Less stuff to worry about.
Discussion Starter #10
That's just it, I'm old that means I don't have to work too hard to board around just push the button......lol Great for car shows and stuff since Hot August Nights is coming up.
Understandable, I salute you sir! Boosted Boards has been making electric skateboards for a while.
Another option if you're interested would be to set up a pumping board (one or two good pushes, then just pump to keep it going) but those can get pricey and the bushing combos are hard to dial in. Consider getting a regular skateboard but fitting it with 1/4" soft risers and 56-58mm soft wheels. Good bearings help also. You'll have to push a bit but it would be way cheaper than an electric board, and more comfortable (arguably) than a full size longboard.
Discussion Starter #12
Great set-up on the pumping board and boosted boards cost 3x maybe you are getting what you pay for. Thanks for the ideas!
1 - 12 of 12 Posts
