1 - 7 of 7 Posts
Hey im considering buying the mickey thompson baja atz radial slt tires. does anyone have these on their x? Im not sure if they make them in a 265/70-16 size (same as stock) but i was wondering how much worse gas mileage would i get with a 265/75-16? I would rather stay same size as stock. any other suggestions on all terrain tires?...besides the cookie cutter bfg's.
I had MIckey Thompson mtz's in a 265/75/16. I know they are not the At's but I love Mickey Thompson tires they wear very well. Switching from 70 to 75 you wont notice much of a difference. All the OR models come with a 75 profile stock rugged trail tire.
x-mann, no reason not to go to 265 75s; they're basically "stock" too, since the OR trim runs them. IMO, they look a bit better, and will get you that much more clearance under the diff and traction off road. And on road, you may get a sturdier tire, depending on what load ratings etc are offered in the different sizes. The "same" tire is often different in the different sizes, and 265 75s are a nice standard LT size and are usually rated D or E--and more easily replaced in a pinch since they're a more common size.
Mpg differences are going to be minimal.
Discussion Starter #4
Rite on! thats what i needed to hear. Thanks miles and d-rap. hey d-rap what kind of susp do you have on the front end? Ts? also what kind of tires do you have?
It's custom, 2.5" King coilovers, remote reservoir, SLR upper arms, Titan lowers (boxed), Sway-a-Way longer half-shafts, extended tie rod ends and Light Racing hydraulic bumpstops. Works great.
Too bad the guy who worked the magic is out of biz.
Discussion Starter #7
thanks D-rap. Your x is sick. Cant go wrong with kings. Hey is there any photos of your x on this site?
1 - 7 of 7 Posts
